So around 4th of July week I bought some 2" Sched 80 pipe. It only has a wall thickness of 1/4". I thought 2" inch sched 80 was 3/8" wall. Am I missing something, or did I ask for the wrong thing. The I.D. is 1 3/4" and the OD is 2". Did he give me tube?Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Sounds like you have mechanical tube. But if your OD is 2" and the ID is 1.75 that means your wall is only .125 and not 1/4 like you've said.2" sch 80 pipe has a 2.375 OD and a .218 wall.
Reply:Originally Posted by HT2-4956Sounds like you have mechanical tube. But if your OD is 2" and the ID is 1.75 that means your wall is only .125 and not 1/4 like you've said.2" sch 80 pipe has a 2.375 OD and a .218 wall.
Reply:Sorry to butt in, but if your OD. is 2", and your ID. is 1 3/4, than your wall thickness is 1/8"....
Reply:Info hereLast edited by GlenC; 07-27-2014 at 05:54 PM.GlenMiller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45Want to sell!! - Hobart Handler 150
Reply:Originally Posted by smilexelectric.125 is 1/8" the difference between 1 3/4" and 2" is .25. What kind of pipe should I asked for?
Reply:Nevermind it is 2.375, Is this the pipe the pipe they use on the 2" pipe tests? This is so confusing, why do they say 2" sched 80 weld test if the pipe isnt even 2"Miller Maxstar 200 SDPiperliner #10 Gold
Reply:That is not even half of it. After a certain diameter SCHD STD is different to 80 and SCHD XS different to 160.Also for pipes with threading (galvanized pipes etc) 3in is 76.1mm instead of 73mm.Madness I tell you
Reply:??????????????????????
Reply:Originally Posted by taz00That is not even half of it. After a certain diameter SCHD STD is different to 80 and SCHD XS different to 160.Also for pipes with threading (galvanized pipes etc) 3in is 76.1mm instead of 73mm.Madness I tell you
Reply:Please shoot me.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Unfortunately I am not joking.Check out this table:http://www.tubularsteel.com/docs/schedule_ansi_pipe.pdfYou will notice that from 12in and upwards, STD and 40 have different thicknesses.For 80 and XH the change occurs at 10in.
Reply:So what do I use for this 2" sched 80 test. Its tig all the way out with er70s-2. Did I get the right thing?Miller Maxstar 200 SDPiperliner #10 Gold
Reply:If the pipe you bought has a 2.375in OD and 0.218in wall thickness then you have the right pipe.
Reply:Originally Posted by smilexelectricPlease shoot me.
Reply:Originally Posted by DSWNo, no, no... We have enough problems with gun control.Please fall on your tungsten ( swords are usually in short supply most places) instead, (Pointy end of the chipping hammer will work in a pinch). Or commit hara-kiri with a kitchen knife.
Reply:Originally Posted by taz00You forgot to mention that the tungsten should have been ground lengthwise, if not, it will not penetrate easily and he will suffer a slow and painful death
Reply:You guys are ruthless. Now i know i am at home here!Smile, it is total madness but probably based on something obscure from 100 years ago...GravelThe difference between theory and practice is that in theory there is no difference.
Reply:http://en.wikipedia.org/wiki/Nominal_Pipe_Size
Reply:The size refers to the NOMINAL inner diameter of the pipe, so if you ask for 2" SCHanything, don't ever expect your tape or measuring device of choice to read 2" on the OD. For pipe, the nominal OD does not change, but instead the ID does. So 2" sch40,80,&160 all have the same OD.Think of it like a 2x4 . . . it's not a 2x4 MikeConstans Fides et IntegritasLincoln Weldanpower 150 ACAirco Aircomatic MIGet CAV II w/ spoolgunMillermatic 30a wirefeeder |
