Mesh cooking rack
发表于 2021-8-31 23:03:56 | 显示全部楼层 |阅读模式
I've got the itch to make me a grill that you put over top of a camp fire, I've got all of the material to do it from left over projects from past years. Looking on the internet a lot of them seem to be painted. Would high temp paint be suitable for this like what you get at the auto parts store or should I get paint that is made for grills and the such. I'll be cooking directly on the mesh surface so it's gotta be something safe to eat off of.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:I'd do the old standby and oil season it just like you would a cast iron fry pan. Just use something like olive oil or some other cooking oil..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Contact with food? NO PAINT WHATSOEVER!Any coating will fail from the heating/cooling cycles. You don't want to eat that.Season the steel by applying a liberal coat of VEGETABLE oil and heating it. Do this several times. You will have this tool for the rest of your life. Look up how to season, use and clean cast iron cookware.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:gotcha, from what I was seein online they appeared to be painted. I'll go the route of seasoning it like you do cast iron skillets.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:Some of them do paint them but they need to be burned clean and seasoned before using.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:What you might be seeing is ones that are porcelain coated..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:OP is correct. Cabela's has some that are painted for camp stoves and they need to have the paint burnt off before you use it. They do this so it wont rust while it is being shipped. I have one and I just burnt the paint off as it said in the instructions. Then I re-season it with pam after Im done using it. But YOU CANNOT eat off until paint is burnt off. NOT good. But as other's have said vegetable oil works as well in a spray bottle so you dont waste as much or brush on with a basting brush when grill is still warm.Last edited by OUTBACK FORGE; 07-31-2014 at 10:35 PM.GalenMiller TrailBlazer 302 EFIThermal Dynamics 252i w/WeldCraft WP 9F tig torch and foot controlThermal Dynamics Pak 52Millermatic 250 w/Spoolmate 30aLincoln SA-200 gas driven welder from grandfatherBlacksmith shop
GMT+8, 2025-12-28 13:49 , Processed in 0.096142 second(s), 18 queries .
