Firewood door
发表于 2021-8-31 23:03:52 | 显示全部楼层 |阅读模式
Firewood door, blackened steel with aged copper insert Attached Images
Reply:Tells us more about that copper sheet, its stunning! where did you find it? What exactly is the black finish on the steel?
Reply:Great looking door! I like that copper. Has a nice rustic appearance overall.
Reply:Both finishes are done with chemicals, the steel is done with an acid that is applied cold. The copper is done with a mix of chemicals burnt into the surface. Then it was all waxed for the final finish
Reply:Beautiful, great work!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
GMT+8, 2025-12-28 12:03 , Processed in 0.102339 second(s), 18 queries .
