Oxy-Acetylene Torch Bench Stand
发表于 2021-8-31 23:03:47 | 显示全部楼层 |阅读模式
Anybody got a good design for a bench stand for a torch.  I need something that will hold a torch between heating up the workpiece and bending over a vise dolly or in the vise.Thanks,Tom
Reply:If you plan on setting the torch down a lot you might be better off getting a gas saver.  Enco sells them and you can see a pic in the online catalogDennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-28 13:48 , Processed in 0.098593 second(s), 18 queries .
