What oil do I service my compressors with?
发表于 2021-8-31 23:03:44 | 显示全部楼层 |阅读模式
What oil do I service my compressors with?  Its a big one from IR, 25hp.  Its a 30T i think.  Thanks.
Reply:I would use the oil that IR sells for the compressor - it's a special blend.  I think that you can order it online from Northern Tool.
Reply:I use special compressor oil from WWGrainger, Its expensive, but that is all it is made for.
Reply:Use IR synthetic oil, made for your compressor.  You should be able to purchase it at the same place you bought your unit.  Don't forget to change the air filter too.
GMT+8, 2025-12-28 12:03 , Processed in 0.100418 second(s), 18 queries .
