A coworker picked up an old Airco welder/generator and was wondering what the front plate should look like. I struck out on google. So here are some pics of the machine:Any ideas?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Its a relabeled Miller I just cant remember which Miller I wanna say its either a Roughneck or AEAD not sure.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:http://www.millerwelds.com/om/oi411a_mil.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks, that was a fast reply. You must have had one of those things.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Nope. Just did a quick comparison with earlier AEADs.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Brainfarth, don't let him fool you! He knows is schtuff...GravelThe difference between theory and practice is that in theory there is no difference.
Reply:This looks right Attached ImagesDave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by Brainfarth
Reply:Yup...Common sense in an uncommon degree is what the world calls wisdom. |
