Tough gun
发表于 2021-8-31 23:03:36 | 显示全部楼层 |阅读模式
Hello Folks   I am in need of a .023 " liner for a  200 amp  gun  LWS don't carry it and can not find it , also tried to hook it up to a  MM 252  and it leaks argon at the roller assembly    any ideas?
Reply:What brand gun?Is the o-ring missing on the liner head?What size liner was in the gun to begin with?  A .030/.035 and even .045 liners have been used successfully with .023 wire by myself and many others here.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hmmm,they have a liner for a Tregaskiss Tough Gun for .023,http://www.tregaskiss.com/files/Line...Steel_Wire.pdfBut contact tips seem to start at .030.
Reply:It had .035"  liner   tried  it with no luck,   I have some  .023"  tips  but could not locate the proper liner   L W S ordered me one  but  not the right one. tried the o35" again   but still birdnests on me
Reply:sorry   yes there are  2 o rings    still  new on it
Reply:Originally Posted by SNUNEZIt had .035"  liner   tried  it with no luck,   I have some  .023"  tips  but could not locate the proper liner   L W S ordered me one  but  not the right one. tried the o35" again   but still birdnests on me
Reply:Originally Posted by SNUNEZ. . . also tried to hook it up to a  MM 252  and it leaks argon at the roller assembly    any ideas?
GMT+8, 2025-12-28 11:55 , Processed in 0.073819 second(s), 18 queries .
