Dumb question.. Hot rolled and cold rolled.
发表于 2021-8-31 23:03:33 | 显示全部楼层 |阅读模式
What's the difference other then one is hot and one is cold?   I'm "hopefully" closing on a condo this month and was thinking of making some end tables for my bedroom, the legs will be 2" square, 1/8" wall.  I like the whole metal and wood thing, so I'm combining them.  I never understood the differences, ( as welding is currently more of a hobby) and I want to buy the right materials.www.thefusionsolution.com
Reply:Hot rolled comes out of the smelter red hot and is rolled at that state to size. Cold rolled is formed a second time from hot rolled that has cooled to cold. Cold rolled rolling gets rid of the heavy scale caused by oxidation of the hot worked meta. It also forms the crystal structure into drawn out shapes which make it just a little harder and stronger. There are more complications than this but this is a simple answer and I do not want to dig out the book work to complicate this.   Mac
Reply:lol! that's ok, I appreciate it, I understand it better. thank you.www.thefusionsolution.com
Reply:A little info on cold rolling:http://www.ussteel.com/uss/portal/ho...vZ0FBIS9nQSEh/"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Awesome, thank you!www.thefusionsolution.com
GMT+8, 2025-12-28 11:55 , Processed in 0.072857 second(s), 18 queries .
