ac/dc 230 volt tig
发表于 2021-8-31 23:03:28 | 显示全部楼层 |阅读模式
look,ing for suggestions on what brand of machine to buy,im welding aluminum and stainless from 2.5mm to 6mm,the weld length is approx 10m ,watercooled torch etc
Reply:Any of the 3 or 4 major brands are okay. Personally, I like Miller. You will also see the Hobart units look strickingly similar to the Miller units for some reason. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-28 11:54 , Processed in 0.073503 second(s), 18 queries .
