hypertherm max20 Plasma cutter repair
发表于 2021-8-31 23:03:24 | 显示全部楼层 |阅读模式
I have a hypertherm MAX 20  ight duty plazma cutter I picked up used that does not work. When air and power or applied it lights the temp pressure light  which best I can tell from the owners manual means my air pressure is regulated properly .  It also passes the test switch procedure according to the manaul .  But when I try to cut it makes a small arc and then stops.  Consumables in tourch are used but look to be in working order as compared to other plasma cutters I have used .  Can anyone tell me where I can find a schematic or a repiar manual  to go along with the owners/ operation  manual I already have  so I can try and repair this unit.Thanks in advance.
Reply:I don't have much plasma expirience but I would try new consumables.  Clean the torch tip out and make sure you have a good ground.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-28 13:47 , Processed in 0.101390 second(s), 18 queries .
