查看: 13|回复: 0
MIG wire
发表于 2021-8-31 23:03:22 | 显示全部楼层 |阅读模式
i am clearly a noob mig welder. is this the proper wire for steel? just regular old metal are steel. mile steel.http://www.lowes.com/pd_178742-1703-...ductId=1156695Zach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:Yep. Its gas-less fluxcore welding wire to be used straight polarity. Used for welding mild steel.Nothing Ever Got Done By Quitting, Never Give Up.
Reply:good good thanks manZach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:Yes, that's the right wire for mild steel. Depending on the size of your machine you may be better off with .030" though.Lincoln 175HD
GMT+8, 2025-12-28 13:48 , Processed in 0.100813 second(s), 18 queries .
