invertec v275s vs v350 pro vs XMT 304 cc
发表于 2021-8-31 23:03:19 | 显示全部楼层 |阅读模式
I am looking at buying one of the three.  I want to use it strictly for stick welding pipe.  I hear a lot of talk about how awesome the v350 is but what i want to know is it surpass the v275s  in strictly stick welding?  I know it has a serious amount of functionality for pulsed mig and stuff like that but I will not be using it for that.  I heard someone on the forum say they could dial a v350pro to run like a shorthood, does the v275 have that kind of manipulation?  Also toying around with the idea of getting an xmt 304 cc only.  Any insight would be helpful and appreciated.
Reply:I have no experience with either Lincoln but I have used the XMT304 and 350 a fair bit. All ran on 550v 3 phase power.I don't believe you can buy a new xmt today that is cc only? cc/cv only.All the xmt's are excellent stick welders. They are great shop pipe welders. Very smooth.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Any solid transformer can stick weld pipe, though both the XMT and the Invertec can lay down quality stick beads. Shelling greenbacks for a fine inverter to only do stick welding is ok, but may be needless in a prudent sense. However, I like the Invertec better (I have only run the V350 Pro when I certified) than the XMT 304 cc/cv (which I own). But as far as dialling in super-sweet stick passes for pipe, it is just not something I have invested time in. You would do better to hear from the pipe weldors aboard.Good luck! Last edited by tanglediver; 10-11-2012 at 11:37 PM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I ran the V275-S till I sold it, thing welded like a dreamGood luckGod speedSent from my iPad using Tapatalk
Reply:Originally Posted by hituw2x4I want to use it strictly for stick welding pipe...
Reply:330ABP miller or Airco.  Same machine if u don't need portability will weld every pipe u ever need and also a great tig machine.     Going price is about $500.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Inverters have completely different arc characteristic than transformers, look at the output graphs in the back of any manual and you will see. I have never use a V350, but I have used the XMT & V275 quite a bit. The XMT has adaptive hot start, which seems to work pretty good, the V275 hot start is all or nothing, and it is just a quick blast. I don't much care for it. The XMT has limited arc force control, basically 2 or 4 settings based on the model. Either set it on 6010 or 7018. The Lincoln gives you infinite adjustment which I like because I like, because you can tailor arc force  for big or tight gaps on my root. I like the XMT digital readout for repeatably, the V275 has a very small dial with just over 180 degree swing, so its really hard to make minute adjustments let alone repeat them.The V275 can be had for less than a grand, the XMT will be just under twice as much in the used market.Constant Current Weldor.
Reply:I forgot to mention I have two idealarc 250s an a ab 330 running all day and a miller mig welder being ran occassionally.   Figured I could shave off some from the electric bill while upgrading equipment.  I have a everlast power arc 300 that I got just to see how I like it but that's like my personal machine for just jerking around at home.  I like it alot but not sure how it would fair in a commercial environment.
Reply:In my opinion, the XMT has a violent arc and I didn't really see what the hype is. When I tried the V350 Pro, I was absolutely amazed at how smooth and buttery the arc was. I really can't imagine how nice the SA200 is."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manWhen I tried the V350 Pro, I was absolutely amazed at how smooth and buttery the arc was. I really can't imagine how nice the SA200 is.
Reply:CEP after reading all your posts on the v350 pro i got to try one!!  You should work in sales at Lincoln Electric, you'd sell a ton.
Reply:Yeah I guess I lean towards Lincoln, but my Miller Dynasty made a Tig welder out of me. Trust me this is all machine, the Dynasty does it all, all I have to do is turn it on. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Should be jewelery!
Reply:Originally Posted by Rick VFirstly, I'm not known as a 'stick welder' on this forum.Thus, I tend to agree with tangledriver - for stick only, why pay for an expensive 250 amp inverter when a 250 amp transformer welder would do for a lot less money?  If you really need big output current like 250 amps for running large 1/4 inch electrodes, then I go looking on Craig List or Kijiji for a used Lincoln Idealarc AC/DC - renowned for the quality of their arc and a 30% duty cycle at 250 DC amps.  Depending on age, around me they are advertised for about $400 for a older round top (rare) to $800 - $1000 for a new model less than 5 years old.
GMT+8, 2025-12-28 13:46 , Processed in 0.114268 second(s), 18 queries .
