Jet saw
发表于 2021-8-31 23:03:19 | 显示全部楼层 |阅读模式
Does anyone know this type of saw? Is it a good saw and are blades still available for it? Attached Images
Reply:Looks like a power hacksawhttp://www1.mscdirect.com/eCommerce/...ades/_/N-77h0lNickESAB CaddyTig 2200iPowermax 45MM140 (Sold)
Reply:worth $75 if working properly?
Reply:I don't have any experience running those machines but that tape job on the power cable makes me nervousNickESAB CaddyTig 2200iPowermax 45MM140 (Sold)
Reply:Google search found many similar machines. I'd give $50 just because I think it's cool. More like a mounted sawzall...if anything. I'm sure blades are available somewhere online. Attached ImagesPOVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:The bandsaw pretty much put those out to pasture, but if properly adjusted, nothing cuts straighter. They are slow and that's the biggest drawback. And Yes, you can still get blades for them. I have two, one working and one in storage. The last time I used it was to cut 6" square tubing and when I was done, you could put a square on all four side and it was dead on. $50-75.00 is about what they go for.
Reply:we had a mamoth power hack in an old shop i worked in for a few years i was bumbed when we went to the band saw the power hack had lost a gear when the idiot helper tryed cutting stainles with everything turned way up....what happened? i dont know i set it like we are suposed to for aluminium and boom the gear came apart.....grrrrr
Reply:Originally Posted by makbootzyDoes anyone know this type of saw? Is it a good saw and are blades still available for it?
Reply:Horizontal mill is to shaper as bandsaw is to...  I've never run a power hacksaw.  Always wondered what sort of cut rate they had.  I'm sure they're slow but how slow?  How long to get through a 1" round?  Also, are blades available in a range of TPIs or are they all "hacksaw" blades?Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Originally Posted by wendellHorizontal mill is to shaper as bandsaw is to...  I've never run a power hacksaw.  Always wondered what sort of cut rate they had.  I'm sure they're slow but how slow?  How long to get through a 1" round?  Also, are blades available in a range of TPIs or are they all "hacksaw" blades?
Reply:Just to give you an idea of the speed, it took 45 minutes to cut a piece of 3" bar. But it was dead on square and you never have any heat issues. Wendell is right, the bandsaw did in the power hacksaw, the horizontal mill did in the shaper, and the vertical mill just about did in the horizonal mill. Progress.Last edited by trapperjohn; 02-16-2013 at 11:02 AM.
Reply:I hadn't seen one of those since early 70's - some of the quy's i work withwould take the blades and make knives out of themThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:Had one of those in a shop I sold a few years ago.  It was a lot bigger and had built in coolant tank and pump.  It did cut real straight.Draw backs were, it was noisy, not real efficient as it only cuts half the time but not a big deal to most people and if you are cutting smaller stuff all the time it only uses part of the blade.Blades were easy to get from our supplier at the time although I don't remember cost.
Reply:Seems like blades for that would be cheaper than buying blades for my bandsaw. Making buying spares easier to swallow.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:A shop I worked at in the early 80s had a big Marvel power hack saw we would cut off       8"dia stock for furthur CNC machining.  I think the blade had eithe 4 or 6 TPI and shook the floor on the pull storke.  It was all mechanical/automatic with clutches and trip switches.  We saved a miss cut that was less than 1/8" thick that was true as could be.  Sold for $65.00 at their closing out sale. Dan D.
GMT+8, 2025-12-28 13:48 , Processed in 0.092888 second(s), 18 queries .
