Valentines Day Roses Done Finally
发表于 2021-8-31 23:03:19 | 显示全部楼层 |阅读模式
Here is my fiances valentines day present finally finished.  It is 5 mild steel roses that are black oxided with 1 stainless steel rose in the center which was sandblasted and colored with a oxy fuel torch.  It is kinda hard to see the color in the pictures.  The rose stems were scrolled and textured to all meet as one at the bottom and tig welded together.  The vase is made out of a piece of schedule 80 2 inch pipe.  I forged the bottom down and forged welded it together to a point and split the top and drawed the sides out and flared them.  Drilled some holes and stiched them back together with 3/32 copper flashed steel tig wire.  The vase holder is a piece of stainless steel 1/2 inch rod which I scrolled around and down and sandblasted it also and heat colored it.  Finally everything was clear coated with Rustoleum Crystal Clear paint.  Hope you guys like the pics.
Reply:Great job! Fair play
Reply:The petals are beautiful.This is absolutely, unequivocal beauty. Winner!PlasmaCam CNC cutterLathe and Band SawClamps
Reply:They look great, and will last a bit longer than the real thing!JackFort Loramie, OhioMilermatic Autoset 180
Reply:Well done!http://www.facebook.com/LockhartMetalArthttp://www.facebook.com/pages/Grumpy...44306259043484
Reply:Very nice job - gonna make someone very Happy
Reply:thanks guys, everyone I know made a single rose so I figured I set the bar a little higher for everyone next year ha.
Reply:Tho look good here mine. Attached Images
Reply:thanks guys, scoot i like yours alot a little different pattern than mine, but still great fabbing.
GMT+8, 2025-12-28 11:54 , Processed in 0.098335 second(s), 18 queries .
