Aluminum mig vertical down.
发表于 2021-8-31 23:03:17 | 显示全部楼层 |阅读模式
Just a bead that I ran at work the other day. Millermatic 350p with python gun. I thought it looked pretty good. Attached Images
Reply:Why would someone even post a photo of a weld that looks like that. REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:Originally Posted by Old SkoolWhy would someone even post a photo of a weld that looks like that.
Reply:Don't mean to be rude, but I wouldn't call that a good result.
Reply:No details on material thickness, settings used etc.  Hard to provide much feedback.   Ok if sorta looks like a real crappy tig,  but its mig and the bead should look like a mig bead.  Not like ... umm like whatever that is.If u gave more details and asked for feedback suggestions u would get nicer responses.   U may think it looks good but that has nothing to do with if it is a good sound weld.Last edited by soutthpaw; 02-18-2013 at 12:58 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:looks like a "mig like tig" on alu, if you make the beads closer together... it could at least look better .--------------------------------------------------------------www.becmotors.nlyup, I quit welding.. joined welder anonymous
Reply:To me it looks like an aluminum MIG deposit on top of stainless.
Reply:Here is some positive feed back I the good points are it is prety consistant but as was said before it shouldn't look like a tig weld what you have going good for you is you are consistant with your whip but you aren't overlapping enough you need to come back and cover about 3/4 of the puddle you whipped out of with out knowing settings and material thickness we can't offer much more help than that
Reply:It is 1/8 to 1/8 with an 1/8 gap between. I am working on the consistency of my whip. I will try to bring it a little closer together and post the results. I just think constructive criticism is the best way to get a point across, instead of, uh, wth is that.
Reply:Well I can't see the beggening or termination of the weld but I'm betting you have cavitation whe you start the bead pause let your puddle build start your whips keep them tight you want a build up you don't want a flat or concave weld it should have a buildup on top when you terminate the weld pause again to finish
Reply:http://weldingweb.com/vbb/showthread.php...11#post2298111
GMT+8, 2025-12-28 13:49 , Processed in 0.081077 second(s), 18 queries .
