查看: 13|回复: 0
Aluminum ball field drag.
发表于 2021-8-31 23:03:16 | 显示全部楼层 |阅读模式
Bossman at work wanted a 48" drag for his daughters softball team home field. Sure thing boss. 48 of these little buggers.Yes I cheated and drilled the long parts on the mill first. Spaced 2" and offset. Didnt quite get it finished Friday. So yesterday I drug my youngest away from the xbox for a few hours to go to the shop and "help" me. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
GMT+8, 2025-12-28 13:47 , Processed in 0.071034 second(s), 18 queries .
