Advice/help needed any reason im not getting any hits?
发表于 2021-8-31 23:03:10 | 显示全部楼层 |阅读模式
Structural or repair welding services offered. 15 years experience in shop or mobile welding. I have done it all from cattle guards, entrances, pipe or square tubing fences, metal buildings, portable buildings, pier and beam, bridges, arenas, boat docks, car ports. As well as plenty of experience in repairs, anything from trailers (large belly dumps, 40' goose necks), ag equipment such as swathers, bailers, bobcat buckets, plow blades, harrows or anything in between.
Reply:Is your region currently experiencing an economic slump?How are you advertising?Magnetic signs on your company/personal vehicles?Leaving business cards in public places or other business you frequent (with their permission of course)?Visiting other local businesses that may require your type of services?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:http://probaseballinsider.com/baseba...ls-of-hitting/
Reply:Originally Posted by 12345678910http://probaseballinsider.com/baseba...ls-of-hitting/
Reply:Must have been a long week but then he IS a numbers kinda guy. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Where you located.
Reply:Welcome.  An idea of where you are (post in your profile) might enable people to better help you.  Strange introduction.  Glad to see you don't have aerospace welding experience.  Again, welcome.JerryLast edited by storeman; 08-08-2014 at 09:27 PM.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:This part of US is booming. Attached Images
Reply:I'm around the north central texas area. Thought I'd get the truck lettered soon as well. What are some primary equipment or services needed within this field?
Reply:He'll be here all week folks!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by tmcelroyI'm around the north central texas area. Thought I'd get the truck lettered soon as well. What are some primary equipment or services needed within this field?
Reply:It might also help if you identified where you did your post that is getting no "hits".  Might not be the best place to advertise your services.  Fellows here would likely be able to give some tips on marketing venues.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
GMT+8, 2025-12-28 11:54 , Processed in 0.098489 second(s), 18 queries .
