Old Forney Welder!
发表于 2021-8-31 23:03:09 | 显示全部楼层 |阅读模式
Mom's John Deere rider mower had the spindle torn off the sheet metal tube axle about 10 or so years ago.It was pulling away again where it had been welded previously.Brother A tells Brother B who mentions it to me(Brother C).I go home with some Eutectic Arc-Alloy Repair 3/32" rod, Helmet and Grinder.Find a Farmer neighbor with a welder, hence title of post, he also uses the disclaimer of he can only weld flat to which I tell him no problem I can weld it.He and I take the spindle out, drop a bolt in the hole, heat and bend it back into position.Grind it out, when he says he has only 20 year old rod, I reply no problem! Then he says "Oh, sorry the lens fell out of the helmet", to which I reply no problem I brought mine!I laid one of the best vertical welds I have ever done (actually it was the rod at 65amps)!After he exclaims it is beautiful even in his old eyes!I tell him I was lucky!Only regret is I wish I had taken pictures of the previous repair and my weld.Maybe next time I am home, I will!I had never ran a Forney that I can remember(?) but was impressed at how smooth it ran the rod!
Reply:Forney made a lot of stick machines, and  like a Timex, they keep on ticking.
Reply:I love old Forneys!   I even like their current production green colored AC/DC stick model.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Sounds like everyone is more than happy, good job.My Father-inlaw had a 1950's Forney multi-tap farm welder that was a beast, and welded like a dream. A grandson has the machine now, but he needs to replace the capacitors.
GMT+8, 2025-12-28 13:48 , Processed in 0.096920 second(s), 18 queries .
