Buffalo Ironworker
发表于 2021-8-31 23:03:05 | 显示全部楼层 |阅读模式
Hey guys.. Im new here but have some questions... I just picked up a buffalo ironworker model 0.  I was wondering if there is any info out there on what all it can be set up to do. I understand the basics but Im sure there are somethings that it can do that I dont even know about.
Reply:IRONWORKERS3" x 3" x 3/8" Buffalo #0, 30 ton, extras, tooling, 1956  BUFFALO UNIVERSAL IRONWORKERMODEL NUMBER                  0YEAR OF MFG.                  1956TONNAGE                        30THROAT DEPTH                  12"ANGLE CAPACITY @ 90 DEGREE      3" X 3" X 3/8"       @ 45 DEGREE      2" X 2" X 5/16"MAXIMUM NOTCH                  2" X 2" X 1/4"MAXIMUM COPE/NOTCH            3" X 2" X 1/4"FLAT SHEAR                  7" X 3/8" OR 4" X 1/2"ROUNDS                        1 1/4"SQUARE                        1 1/8"ELECTRICAL REQUIREMENT            42 Amps. 220/440V-3Ph.APPROX. WEIGHT                  1,500 - 2,000 lb.F.O.B. POINT                  FL.EQUIPPED WITH:      PUNCH, SECTION SHEAR/BAR SHEAR, FLAT BAR SHEAR, COPER &        NOTCHER WORK STATIONS, ONE SHOT LUBE, CASTER BASE, LENGTH            GAGE, WORK LIGHT, MISC. PUNCHES/DIES & MANUALS.THIS MACHINE CAN BE TOOLED TO CUT ANGLES, TEES, I-BEAMS & CHANNEL.Thank you for internet.............
Reply:I have that info. But was wondering if there is anything else out there. Besides the basics.
GMT+8, 2025-12-28 13:46 , Processed in 0.092221 second(s), 18 queries .
