查看: 2|回复: 0
Need Scroll Bending Help
发表于 2021-8-31 23:03:05 | 显示全部楼层 |阅读模式
Has anyone used the scroll bending attachment to the HF bench bender?I'm having some trouble getting smooth bends, and cant figure it out.The directions were a bit vague, but I know it's me not the machine.
Reply:It's the bender.  If you look you will see the inner small die has a flat spot at the end of it's reach right before it transfer to the outer die.  Just build the flat spot up with some weld and grind it back to a smooth arc.  That will greatly improve the appearence of you scrolls.  I'll try to find a link to a thread on the Hobart site.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Here's a link.http://www.hobartwelders.com/mboard/...light=scrollerDennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:ThanksNever would have guessed.
GMT+8, 2025-12-28 13:49 , Processed in 0.072496 second(s), 18 queries .
