Thermal Arc 186 and cart setup.. My new setup
发表于 2021-8-31 23:02:55 | 显示全部楼层 |阅读模式
So I finally got around to unbolting my HF cart and T/A 186. I added some rod holders to both sides of the cart. I'm happy with the way it came out. I wish the top tray on the cart was an inch longer so the entire foot of the welder was on it, but it's sturdy enough either way. The most I'll ever move that thing is 10 feet.Last edited by Stewi; 02-17-2013 at 11:15 PM.Reason: photos not working
Reply:sorry about the photos. I just finally got them working.
Reply:Where did you get the rod holders? I have the same cart and built a little handle for the front. It's good for the price but it really needs bigger casters up front.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:They are rod guard rod holders. I got then from cyber weld for $12/each. I used brackets meant to hold up metal conduit from Home Depot for $2 each.
Reply:nice set up how you like your machine so far I just bought oneMILLERMATIC 212 AUTOSETMILLER BOBCAT 250MILLER DIALARC HFMILLER 15A SPOOLGUNMILLER S32P WIRE FEEDERTHERMAL ARC 186 AC/DCPAKMASTER 100XL PLUS
Reply:You need to get 4 more straps for the rod holder tubes and put on the bottom to keep them straight.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by Drf255You need to get 4 more straps for the rod holder tubes and put on the bottom to keep them straight.
Reply:Piece of heavy sheet metal at a 90deg angle with the proper hole cut in it should work. If you want the front feet of the welder on the shelf you could cut a piece of plate the size of the shelf and add the 1" you want. I would be tempted to add a little more and have it so you put some tools on it maybe some wire brushes and such.
Reply:How do you like that machine? I was thinking about it...Hobart 187 migLooking for tig
Reply:Originally Posted by djhenderlongHow do you like that machine? I was thinking about it...
Reply:Originally Posted by StewiI might use the 2" and run a few beads inside to make the I.D. smaller so I get a snug for around the tube.
GMT+8, 2025-12-28 13:49 , Processed in 0.088950 second(s), 18 queries .
