Razors and Foil Trick
发表于 2021-8-31 23:02:54 | 显示全部楼层 |阅读模式
So dj55b put a thread up about welding razor blades. I put a quick and dirty flat razor welded picture up I wasn't to awfully proud of. When I did that I used what was right in front of me. Which was a 1/16 tungsten , 1/16 316 fill. Turns out I misunderstood the post anyway and put a ugly weld up for the world to see! I still haven't gotten the correct razors but when I do Ill try it out and post it. Anyways heres a better picture with the right tools being used for the job. Also in the background is some foil I melted together just because I couldn't resist after watching that video.... Whats some more fun stuff to melt? Attached Images
Reply:Holy sh!t...you guys are stark raving mad!   POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:Originally Posted by mattwelding85 Whats some more fun stuff to melt?
Reply:Butt weld two shaving razor blades together.DE blades. I can send you a handful to practice on. .004 stainless.I dare ya.
Reply:Yeah send them! Where do you even get them anyway? I don't even buy razors anymore. And by the way ("your work piece! get back to work") I finished (most...) of my work. 316l tubing. Im not allowed to take pictures though. So its foil and razor blades tonight gentlemen!
Reply:Originally Posted by Fnord5Butt weld two shaving razor blades together.DE blades. I can send you a handful to practice on. .004 stainless.I dare ya.
Reply:Pm me your address.  I shave exclusively with DE blades or straight razors.Call me old fashioned.
Reply:I have seen the aluminum foil trick...at least how they did it... What they did ( as far as I can tell) they folded it over then brazed across the same folded area very quickly and created a "weld"...I would like to try the razors as well, problem the H/F...how the hell can I light up when I can't even get through the H/f without blowing the edge off...all I can think is using a copper/aluminum backing...Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
GMT+8, 2025-12-28 13:49 , Processed in 0.071818 second(s), 18 queries .
