Propane Cylinder
发表于 2021-8-31 23:02:52 | 显示全部楼层 |阅读模式
Just a quick question...Will a 20lb propane fit on a cart like this with a 125 oxygen? Miller Dialarc 250 AC/DCWeldcraft A-150VSmith O/P
Reply:Sometimes...doesn't on mine so I just chain it up in the air with the chain that would hold the acetylene bottle.Always meant to make a rack for it up higher where it currently hangs, just not a high enough priority Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by 17jamatoJust a quick question...Will a 20lb propane fit on a cart like this with a 125 oxygen?
Reply:^x2 it will fit. But you will have to reposition the restraints.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Mine fits just fine on a hand cart made for a side-by-side oxy/acetylene set-up.  Only now I have the BBQ (20lb) propane tank sitting next to the big oxy cylinder.  I dumped acetylene all together a while back.  Glad I did.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2025-12-28 13:49 , Processed in 0.098842 second(s), 18 queries .
