Bandsaw Width interchange
发表于 2021-8-31 23:02:47 | 显示全部楼层 |阅读模式
I have an old Johnson horizontal bandsaw and it is stamped on the side to use 93" 5/8in. wide blades.  Generally can I use a slightly different width, like 1/2 or 3/4in. wide, which are more common?Thanks in advanceMark
Reply:Originally Posted by mark460I have an old Johnson horizontal bandsaw and it is stamped on the side to use 93" 5/8in. wide blades.  Generally can I use a slightly different width, like 1/2 or 3/4in. wide, which are more common?Thanks in advanceMark
Reply:SIR,not to be critical, but i think your post shouldread, 93in long, 5/8in wide blade. your post couldbe confusing to some people.wlbrownwright city, mo.
Reply:Originally Posted by wlbrownSIR,not to be critical, but i think your post shouldread, 93in long, 5/8in wide blade. your post couldbe confusing to some people...
Reply:Metalworking bandsaw blades need to have the teeth hang off the edge of the wheels. Usually the wheels will have step turned into them, to hold the blade.Otherwise the teeth get worn off before they can even cut anything.So probably if you put a 1/2" blade on it, it will just wreck the blade.The other adjustment would be the guides- some bandsaws have guides that are adjustable for different sizes of blades- some dont.Not sure about those Johnsons- newer chinese ones have 3 bearings for top and 3 for bottom, each separately adjustable.Generally speaking, most horizontal metalworking bandsaws only take one size of blade- unlike woodworking verticals, which have rubber wheels and can take many sizes.You can order bi-metal blades made to order in just about any size from MSC and Mcmaster Carr.
Reply:That sounds like better advice than I was able to give.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-28 17:39 , Processed in 0.320352 second(s), 18 queries .
