The start of my tube notcher
发表于 2021-8-31 23:02:46 | 显示全部楼层 |阅读模式
Today I received the foundation for my tubing notcher.  It is a 1965 Nichols horizontal mill that has a really nice, small footprint.  Most of the horizontals out there are pretty big, but this one is nice and compact.  Anyway, I am going to set it up as my tubing notcher.  I have been using a borrowed Mittler Brothers "ultimate" tube notcher, but am not terribly impressed with it.  It wiggles and chatters pretty bad - and it is a fairly new one in nice, tight shape.  This Nichols mill has a pneumatic feed system on the X axis of the table which allows you to set up an automatic cutting cycle.  It can also be moved manually, but uses a rack gear and lever instead of a lead screw and crank.  The Y axis uses a conventional lead screw, as does the Z (knee).  So, with a vice mounted via a swivel with angle graduations and v block jaws it ought to be perfect for making my notches.Here are some pictures: Attached Images
GMT+8, 2025-12-28 16:02 , Processed in 0.100547 second(s), 18 queries .
