Anyone buy from carbide.com?
发表于 2021-8-31 23:02:45 | 显示全部楼层 |阅读模式
I was comparing prices on Lenox bandsaw baldes. For my size MSC was $36 and www.carbide.com was $26 - both were Diemaster 2's, welded to length. Any one do business with this company?  ThanksMM 175 w/ spoolgun
Reply:I have not bought from them but have got blades from Tyler Tool with good results and prices.  Not sure if they have what you are looking for.www.overtimeequipment.com
Reply:Blades came in and they are as expected.....This place is legit.....MM 175 w/ spoolgun
Reply:you can buy bandsaw blade stock in a reel for cheap $$ from starrettbut you have to weld it and anneal it after..we get it where i work that way..and its easy to weld with a tig if you dont have a bandsaw welder attached to the saw.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsteryou can buy bandsaw blade stock in a reel for cheap $$ from starrettbut you have to weld it and anneal it after..we get it where i work that way..and its easy to weld with a tig if you dont have a bandsaw welder attached to the saw.....zap!
GMT+8, 2025-12-28 15:57 , Processed in 0.071877 second(s), 18 queries .
