Boom Pole
发表于 2021-8-31 23:02:39 | 显示全部楼层 |阅读模式
Boom poles are nice for picking up things and moving them around. So we built one instead of buying one. Not sure how strong this thing is, but so far so good. We have only used it for skidding logs, but there is more to come. Ours has D rings, hooks, and a square receiver hitch on the end for whatever reason we haven’t came up with yet.This boom pole is designed to work with the trailer mover we built as it saved us material and money, but could be the weak link. Still cheaper than buying a new one, but may not look as good. Remember function over looks thou. Worse case we will build another one that actually hooks directly to the tractor.Trailer Mover thread/post Attached ImagesWe are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
Reply:Check out trailer Mover thread for boom pole.Trailer Mover thread/post.We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
GMT+8, 2025-12-28 17:49 , Processed in 0.121731 second(s), 18 queries .
