My own headache rack.
发表于 2021-8-31 23:02:38 | 显示全部楼层 |阅读模式
took some inspiration from beytill's design and i had a couple days off so I thought I would make my own rack. So far it all just tacked together minus the angle iron to run along the top of the bed. Will be getting that tomorrow and welding it all up. Will also be using beytills idea of the D-rings. Going to plasma cut "Chevrolet" into the empty rectangle up top and bold it in and that will be backlit with led's. And waiting for the lights to show up. Also does anyone have suggestions for mounting to the box? If need be I can make my own brackets but I see lots in store, those aluminium ones. Anyone had any luck with those? Attached Images
Reply:id just weld some studs to your angle and drill some holes through your box and throw a nut on it.heres a couple pictures of an aluminum one i built, which i then sold to a buddy and modified it to fit his ford.I cut these gussets out on my waterjet and welded them in for him Attached Images
GMT+8, 2025-12-28 15:57 , Processed in 0.104068 second(s), 18 queries .
