6ft bushhog
发表于 2021-8-31 23:02:32 | 显示全部楼层 |阅读模式
hey guys the place that I work our bush hog is basically junk bent cracked and broke so we pulled the gear box blade and everything off the frame and now they are wanted me to build a new housing for it and put the old gearbox and things back on it I have built trailers a box blade and other stuff but never tackled a bush hog just courius if anyone else had done it and had any thoughts on the matter thxsMILLERMATIC 212 AUTOSETMILLER BOBCAT 250MILLER DIALARC HFMILLER 15A SPOOLGUNMILLER S32P WIRE FEEDERTHERMAL ARC 186 AC/DCPAKMASTER 100XL PLUS
Reply:Just copy the old one.  I bought a rusted out bush hog and rebuilt it the same way.  Just copied the old one, angle iron and flat plate basically."G"ConductorX - The Volkswright Shophttp://volkswright.blogspot.com/http://bugwerks.blogspot.com/Miller DVI w/Spoolgun - Miller Plasma Cutter
Reply:Ditto.  If you want to change the design for any reason pick up a "GEARMORE" catalog from your nearest tractor dealer for ideas. I used to have one with two trailing wheels instead of one that gouged the dirt a lot less on rough or steep terrain.
GMT+8, 2025-12-28 17:47 , Processed in 0.129024 second(s), 18 queries .
