Plasma circle cutter
发表于 2021-8-31 23:02:29 | 显示全部楼层 |阅读模式
I bought a Plasma torch guide from mechanic416 on eBay. He gives a basic drawing on making a circle cutting attachment. I made mine out of 1/4" and 1/2" aluminum round stock. The nut on the guide is 6x1.0 thread, so I threaded one end of the 6"x1/4" rod to screw into the guide. The magnet was part of a universal circle cutter. I also cut a 12" rod for larger circles. The 1/2" rod is threaded end to end 1/4x20. I cut the head off a bolt so the rod will fit into the magnet base, and there is a set screw in the top to lock the 1/4" rod at the desired length.Last edited by cope; 03-03-2013 at 02:32 PM.
Reply:Free hand!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reply:Originally Posted by mikecwikFree hand!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reply:It is a cool tool and I wish i had one, do not get me wrong. It is also good to expand the talent within the self.
Reply:Very nice brother!!
Reply:I like it, clean and simple.  I'm gonna have to fix my lathe and make one for myself....I think that makes 367 projects on the list and counting...Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-28 15:56 , Processed in 0.071189 second(s), 18 queries .
