Warped smoker door
发表于 2021-8-31 23:02:21 | 显示全部楼层 |阅读模式
Howdy guys, I don't really know how to explain all of this in great detail, but I've really put a "dent" in my smoker.  I've layed about 100 beads on the inside and outside, but I really need some advice on how to fix this mistake.  Just wanting to know where I need to start, which way to pull, and anything and everything else I need to know.  Thanks y'all!Sent from my HTCONE using TapatalkTrash talk stops when the hood dropsDon't cry because it's over, smile because it happened
Reply:I got a hunch you're gonna need a rose bud, sledge hammer, and a large piece of pipe for a dolly to fix this.But first take a # 3 or 4 cutting tip, heat a large line on the inside of the door, and use a spray bottle of water to cool. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:it look like the curve has flattened out.I'd put something in the opened door and hammer the door down, move along as you goIt would stress the hinge, watch that.
GMT+8, 2025-12-28 13:48 , Processed in 0.072219 second(s), 18 queries .
