Service Cart For Welder Cart
发表于 2021-8-31 23:02:16 | 显示全部楼层 |阅读模式
I wanted a cart to hold my new Hobart 190 and my Lincoln stick welder. . I wanted to mount my cylinder on it too, and to hold a lot of other welding tools. . So, I bought a service cart from Harbor Freight.I had a couple L-shaped brackets that was used for a bike rack for a camper, and used that to hold my gas cylinder. . I also made a stand for the Hobart so it would be raised up above the sides so it would get some air.I cut some slots in a couple pieces of pipe to hold clamps, bent metal and made 4 cable hangers, made a rack for each side to hold gloves, wire brushes, hammers etc. etc.Took 2 pieces of pipe to hold my helmets, caps and respirator. . A piece of pipe to stick my MIG gun in!. . On the rack for the cylinder, I just take out 2 bolts and swing the angle iron out so I can change the cylinders.I need to buy some better casters. . The ones that came on it are junk!Here's some pictures. Attached ImagesHobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:More pictures. Attached ImagesHobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:A few more pictures. Attached ImagesHobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:Last one.Its now starting to look like Soutthpaw's cart! Attached ImagesHobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:Nice Job welderBill  Gotta love those service carts.  Those L brackets look a lot like the ones I robbed off an old gas grill for use on my cart.HF Dual Mig 151 with Bluewelders and Galaxieman's modsHF Digital Plasma TorchHF Blue Flames Hood70's era Craftsman 230 stick welderVictor 100 OA
Reply:Nice, great idea!
Reply:Can you give a clearer/closer pic of how you're storing the vice-grip pliers?
Reply:Looks good......I like the way you store the vise-grips.
Reply:Thanks everyone! Originally Posted by joshuabardwellCan you give a clearer/closer pic of how you're storing the vice-grip pliers?
Reply:Originally Posted by Dave1941Nice Job welderBill  Gotta love those service carts.  Those L brackets look a lot like the ones I robbed off an old gas grill for use on my cart.
Reply:The only thing missing is the kitchen sink!  Nice job, especially on the clamps and Vise-Grips.
Reply:Originally Posted by WelderBillThanks! It was your design that I copied off of, If you remember!
Reply:Thats a good idea for the vice grip holder.  And good job on the cart.Thermal Arc 252iHobart StickmateIf you aint burn'n you aint learn'n.
Reply:Nice job really like the clean organized look!!!Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Great looking welding cart.  I really like the vice grip holder. Very well organized.  Amazing how being able to find everything quick makes a project go better.   Richey  sweet home alabama
Reply:Originally Posted by WelderBillThanks everyone!Its a piece of pipe with the bottom cut out of it. . I used a grinder to make the cut. . Then I welded it to a piece of 1/2" angle iron and bolted it on to the rack for the gas cylinder.
Reply:Very nicely done!  I have been thinking about using a HF tool cart (either the 4- or 5-drawer model) as a cart to hold all my OA welding and brazing stuff.  I don't have room right now to put another cart in my workspace, but that is the plan.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:Thanks everyone!. . I wanted a cart to hold everything I needed for welding and to know where everything is! And when I'm finished with gloves, brushes, hammers, helmets, etc. etc. Just hang them back on the cart.I started to build a cart, But thought I would try one of these service carts and for now I'm happy with it. . I may build a cart later on. Originally Posted by Dave1941Remember,,,,,,, what????   Seriously, I may have to borrow your tool rack idea.
Reply:Originally Posted by joshuabardwellDoes that mean you have to pull them out in last-in-first-out order?
Reply:Post #7 in this thread of yours! http://weldingweb.com/vbb/showthread.php?t=246891Your mount for the gas cylinder!  That was my feeble attempt at humor.A mind is a terrible thing to loseHF Dual Mig 151 with Bluewelders and Galaxieman's modsHF Digital Plasma TorchHF Blue Flames Hood70's era Craftsman 230 stick welderVictor 100 OA
GMT+8, 2025-12-28 13:46 , Processed in 0.077666 second(s), 18 queries .
