VERY Simple Project
发表于 2021-8-31 23:02:14 | 显示全部楼层 |阅读模式
With only 20 welded spots and some 1" square tube, this is one of the simpliest projects for anyone. Made the longest piece 15" long, dropped down from the top 4" and placed the legs on in 3" lengths, then cut 3- 1" squares to cover the open ends. After i place it 3" into the ground it will be only 12" tall. After alittle help from a flap disc and some primmer, here is what I have made to go at my grandpas grave.  Still havent figured out what color it will be painted yet. Attached ImagesJobSmart MIG125Lincoln AC225-SLincoln Pro-Mig 175Dewalt GrindersRidgid ChopsawIR Garage Mate CompressorAny thing worth doing, is worth doing right.
Reply:NiceI made about a hundred of those that went on some signs.  It is easy to jig on a flat table and weld away.  It was on those that I learned the secret of downhill 6013.  I was knocking them out.
Reply:That's a nice way to show you care about him.If you get the money later to get a tig or want one Stainless or Alum would last longer.
Reply:I didn't see the part about your grandfather's grave.  I think that is a wonderful thing!  My condolences.
Reply:Very nice job! Hobart Handler 190Hobart Spool-Gun 100Lincoln 225 ACMiller & Pipeliner HoodDewalt 14" Chopsaw, GrindersHarris O/AVictor TorchCustom Built O/A CartCustom Welding CartHeavy Duty 16 Speed Floor Drill PressPipe-BenderDrill Doctor
Reply:Nice work! Grandpa would be proud
Reply:Thanks guys, im still trying to figure out the color, im thinking of blue.  Every truck he had, he sray painted it blue, so i might go with it.JobSmart MIG125Lincoln AC225-SLincoln Pro-Mig 175Dewalt GrindersRidgid ChopsawIR Garage Mate CompressorAny thing worth doing, is worth doing right.
GMT+8, 2025-12-28 13:46 , Processed in 0.098721 second(s), 18 queries .
