obligatory cart project
发表于 2021-8-31 23:02:13 | 显示全部楼层 |阅读模式
I fianlly got sick of the welder sitting on the floor covered w/ a pile of cables.  I've made a couple carts for different welders, it's always a fun project.  I tried to incorporate what I like/ don't like from pervious attempts. 11g 2"  and 1 3/4" square tubing.  1 3/4 DOM push bar/crash bar. GTAW'd.Tall; get the controls up where you can see/touch them.  Keep everything up and out of the dust/ dirt.Front casters are on studs; small foot print.Big rear tires to roll over stuff.  Floor of the cylinder rack is as low to the ground as possible. (what's a 330 weight?)Bottom shelf is expanded metal so as not to hold dust/ dirt. Has room for two totes (SMAW leads in one, 30a and controller in the other). Power source sits on two rails w/o a floor for airflow and to route cables.  Maybe I'll get off my butt and make a new cart for the TIG (fist attempt didn't account for the 1000#+ cGVW!). Attached ImagesLast edited by wendell; 03-08-2013 at 10:43 AM.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Looks great!!
Reply:Thanks Steve but these are solid.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Wendel the solid wheels will become mishapen from sitting in one spot then when you roll it around it will have a limp to it ....I think that's what he was saying
Reply:Gotcha.  If these flatten I'll need your source.  The Swave cart is a "someday" project.  I've got a long torch and a momentary switch if I can't reach the foot control.  With start current and crater fill I get by pretty well.  I'ts rare that I have to move it.  It moves... just not happily.  W/ the chiller and cylinder it's all of a 1K#.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Ha.  We're cool and you're probably right about the wheels.  Don't let those welders get wet!Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Forget the cart...better question is: What is the 4-in-1 bucket attached to??Andrew
Reply:A Killdozer.  I was hoping no one would notice.Syncrowave 300Maxtron 450, S-52E, 30A
Reply:Good looking cart, but your welder reminds me of ET.  Just saying.
Reply:@ wendell - nice talent!  Looks bomb-proof."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Nice work Wendell! Like the mobility and design.Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
GMT+8, 2025-12-28 13:49 , Processed in 0.073969 second(s), 18 queries .
