Tried stick for the 1st time today
发表于 2021-8-31 23:02:10 | 显示全部楼层 |阅读模式
Just a pic of practice weld on a piece of 1/4" steel. 6013 rod. Machine is a Lincoln TIG/Stick welder. Attached Images
Reply:Hello, were abouts upstate are you from?Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Welcome to the world of chipping slag.Stick is and has always been my favorite welding process for it's simplicity and portability features.Some things to remember; never weld over a previous pass without chipping and wire brushing off all the slag from the first pass.You want to pull the puddle behind your arc, not push.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Im from the Lake george Area.Snoepro: thanks for the Advice. From looking at these welds could you tell that I was pushing the puddle as opposed to pulling it? Im asking because Im not sure if i was or not lol
GMT+8, 2025-12-28 13:49 , Processed in 0.098783 second(s), 18 queries .
