304 xmt
发表于 2021-8-31 23:01:59 | 显示全部楼层 |阅读模式
Fellow fabricators.I purchased a xmt 304 auto link. If I am welding SMAW 30 + volts  my fan will run some. Yet If welding GMAW With DX 75 plug and play run .035. 18 to 23 volts speeds 180 to 225. We are full time shop . the fan never kicks in. If we plug in our XR A Push Pull same thing no fan. Yet our xm 300 inverter with our cobermatic push pull runs often. I enjoy these inverters just find this unusual. Both invertors work perfect and are wired with the four pull wire tied back for 1 phase.Any ideasBlackfire operationsClinton
Reply:Do those fans run on demand ? my smaller unit does .
Reply:run for your life shes going to blow
Reply:The fan on the XMT will run when it needs to. Don't worry about it. SMAW cc is set with amps, wire in cv is set with volts.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-28 15:55 , Processed in 0.109258 second(s), 18 queries .
