Back to School pic
发表于 2021-8-31 23:01:53 | 显示全部楼层 |阅读模式
Here's some picks from my classesMe How do my welds look, Cross multi pass filet weld E7018 ( any advice)First try.second tryThird try
Reply:That's a fine job! Keep it up.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:thanks I have to do 30 passes in each positions. For my Certification class.
Reply:The 7018 looks rushed, the toes are not tied in... Fat in the middleLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Thanks i wnt a little bit slower at 125 ampsbefore After (I still on my under cut problem)
Reply:Not bad. Just need to work on rod angle a little.Watch your pool, not the rod and you will be better at keeping even leg lengths.Wait for the pool to tie in to the previous bead before you move, you want to overlap almost half of it.
Reply:Here a little Update!Me again. I finish this side of the projected, ( this pic is not the finish ill upload it when i get home)well time to move on to horizontal!
GMT+8, 2025-12-28 15:57 , Processed in 0.071291 second(s), 18 queries .
