查看: 13|回复: 0
A Couple Recent Projects
发表于 2021-8-31 23:01:53 | 显示全部楼层 |阅读模式
Here's a couple recent projects I thought people might find useful.The first is a little tig stuff caddy.  It holds filler rod, tungsten, torch parts, a helmet hook, and a little tray to hold whatever.  I had it designed and partially build and when I started making the drawers I realized a Huot drill box fit perfectly.  It ended up working better than anything I could have made and saved a bunch of time.  The dividers fit a full length piece of tungsten perfectly.  I still have to pickup some casters to put on it and a rubber pad for the top tray.The second is a little positioner I put together.  I picked up a motor and controller off eBay and the rest is stuff I had floating around the shop.  The rotating main tube rides on ceramic skateboard bearings.  The whole unit angles from horizontal to vertical. Attached ImagesThermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Here's pic of the inside of the positioner.  Please ignore the belt. Attached ImagesThermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:J, your work is really top of the line!!  Your positioner took some thought in the design, I like the through hole concept.  Best  Bob
Reply:Really nice work man! May have to make one of those caddy's love the idea.
Reply:Awesome dude !  That caddy looks like modern artwork . Great design on both.
Reply:Wow! I wish I had that level of fabrication skill
Reply:I like the caddy. And like you said, casters under it would make it mobileAWESOME job on the positioner
Reply:That is some beautiful stuff!
Reply:Do you have any spec of this motor??
Reply:It looks like you put a great deal of thought into both of those!  Well done.  I like those drill boxes a lot.  Thinking about getting one or two for my shop.Do you have a link to the bearings you used?KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:Have any pics of the positioner in use?
Reply:Here's the caddy with the casters on it. Attached ImagesThermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:Originally Posted by Machine_PunkDo you have a link to the bearings you used?Kev
Reply:Originally Posted by sebastDo you have any spec of this motor??
Reply:That's real nice work there. Thanks for showing them.
Reply:Thanks for the spec!!! I'll look on ebay!!
Reply:Great looking and very functional projects. Like the caddy, great idea and very handy. Showed great talent and skills making such. Well done!
GMT+8, 2025-12-28 17:39 , Processed in 0.316442 second(s), 18 queries .
