Ooooooops!
发表于 2021-8-31 23:01:52 | 显示全部楼层 |阅读模式
Brought another load up this weekend.Before I unload, gotta fix an earlier mishapI highly reccomend propane for those who need to heat large pieces.  1 3/4 cold roll."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Don't EVEN ask why there's so many straps on that hay.  It's a DOT thing, and I curse every moment I'm throwing the stupid things over the hay."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Wouldn't one in the middle of the pile to sneak away if it wasn't strapped down.  "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I DO NOT miss trucking. Actually, I hope I never HAVE to see behind the wheel of a truck again!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:you're lucky you didn't get pulled over. You missed one.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Up here they only strap the top bales, IIRCLeo
Reply:where do you buy the hay from? what stateOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I miss driving one, but don't miss working with one at all!From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:Originally Posted by roadkillbobbwhere do you buy the hay from? what state
Reply:Sambo, how did you get the point on that spear? I just know it wasn't with a lathe. Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:I'm betting no need for a front strap due to the headache rack on the trailer.Some blue machinesSome red machineslots of heavy steel
Reply:The number of tie-downs required is dependent upon the size and weight of the cargo transported. According to the Cargo Securement Rules manual, one tie-down is required for every five feet or less in length and 1,100 pounds or greater than five feet but less than ten feet, regardless of weight....just a quick google search Sent using Tapatalk
Reply:Mopar...it was a joke.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2025-12-28 15:56 , Processed in 0.086278 second(s), 18 queries .
