Problems
发表于 2021-8-31 23:01:47 | 显示全部楼层 |阅读模式
Morning, FNG to site so be gentle. Question is : have recently switched from uphill fill and cap (B31.1) exclusively to downhill F & C w/ 6010. And the bottom of pipe is eating my lunch for the moment . Am using Ranger 305G, (does anyone get the downhill mode?) . Any on-topic tips, opinions or links would be awesome.
Reply:Hide your lunch somewhere else so the pipe can't get to it.
Reply:What settings do you have your Arc Control set at?K.I.S.S evading the minds of engineers since the beginning of time.Lincoln Precision Tig 225Lincoln IdealArc 250Lincoln Ranger 305GLincoln SP 185
Reply:Originally Posted by LA_BackwoodsWhat settings do you have your Arc Control set at?
Reply:The downhill feature is supposed to mimic the old SA 200/250 gas burners arc for welding with cellulosic  pipe rod's i.e. E7010, however they run E7018 uphill just fine.Your setting look about right maybe a little cold for a 5/32.If it is the bottom of your weld you are probably moving too slow.K.I.S.S evading the minds of engineers since the beginning of time.Lincoln Precision Tig 225Lincoln IdealArc 250Lincoln Ranger 305GLincoln SP 185
Reply:Originally Posted by LA_BackwoodsThe downhill feature is supposed to mimic the old SA 200/250 gas burners arc for welding with cellulosic  pipe rod's i.e. E7010, however they run E7018 uphill just fine.Your setting look about right maybe a little cold for a 5/32.If it is the bottom of your weld you are probably moving too slow.
GMT+8, 2025-12-28 15:56 , Processed in 0.092816 second(s), 18 queries .
