AWS Vendor night
发表于 2021-8-31 23:01:45 | 显示全部楼层 |阅读模式
Just got back from this tonight in Tyngsboro, MA. I tried out one of the pretty new ESAB inverter based welders on aluminum. Unique sound and feel. Also some new 4047 rod, which the rep said melts a couple hundred degrees lower than 4043. And tried out a 70amp plasma cutter that quickly walked through 3/8" steel in any shape. Would cut 1" steel if there was any there he said.
GMT+8, 2025-12-28 15:56 , Processed in 0.127785 second(s), 18 queries .
