lots of positioner practice....
发表于 2021-8-31 23:01:37 | 显示全部楼层 |阅读模式
Approximately 2,000 of these bad boys.....lots o welding that's for sure. All cnc cut on mill and lathe.Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Wow, that's quite a project!  What is the diameter of the bolts?  Do you do all the welding yourself, or do you have help?JackFort Loramie, OhioMilermatic Autoset 180
Reply:What are those meant to do? The plate seems a bit thin compared to the the stud.Ian TannerKawasaki KX450 and many other fine tools
Reply:Originally Posted by jmhoyingWow, that's quite a project!  What is the diameter of the bolts?  Do you do all the welding yourself, or do you have help?
Reply:Originally Posted by fortyonethirtyWhat are those meant to do? The plate seems a bit thin compared to the the stud.
Reply:Looks good! lotta hood time there.Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:You get all the fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:tig_21  -  Your beads look great, but . . .Welding threads always produce weld fill irregularities. You noted the parts were cut on a CNC and the "Plates are 1/8" with machined hole for stud to fit nice and tight in to prevent from pulling".A stud/threads with a pitch that large may fit nicely, but won'tpocket/seat on a plate that thin, and prevent pull.Was there any consideration at the design level to weldfrom the backside?CNCs don't care, and can change profiles in seconds, so the cost of an additional operation is negligible.The pay-off is fit for manual welding.    If the stud had been turned with a shallow square shoulder that solidly pocketed into the plate, and welded from the backside,you would not have the inherent undercut problem of welding threads.This would be just as strong and more visually pure.Opus
Reply:opus look at the last picture in the top right corner you can see one of the bolts has the threads turned off so it wil seat in the plate...is that what you are talking about? and personally i would have turned a shoulder on the bolts and plug welded them from the back side i think it would look cleaner but since my tig welds dont look as good as some i like to hide them lol
Reply:I want a positioner badMiller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:OPUS,Thanks for the reply and tips. This rod was machined to have a sleeve-like fit onto the plate. You can see from the pictures there is a rod that hasn't been welded yet and shows how it was machined. Because of this, the rod has a flat spot where the sleeve stops and so it sits flat and level with the plate. Therefore, I tack it on one side and move to the other side and do another tack while pressing down on it to make sure it hasn't pulled. I hope that makes sense....I did mention the idea of welding from the backside but based on the thickness of the plate only being 1/8" it would have just been more of a hassle IMO. Welds may look nice but in the end all these are getting powder-coated. I still won't that keep me from performing my best weld every time, even after 2,000 of them.Plates are off to the coaters now. Attached ImagesMiller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Are these being made for tax payers to sit and spin on..Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Wow. Thats a lot of work.Wonder what they are used for?
Reply:Originally Posted by jamesyarbroughWonder what they are used for?
Reply:Generally, with PEM inserts, they say not to deburr the hole.  See page 8:http://www.pemnet.com/fastening_products/pdf/cldata.pdfI see chamfers on the holes in the first two pics.
Reply:I'm also wondering what they are.Giant bolt held by an 1/8" plate?  I don't get it...Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Ya know it's interesting hearing everyone talk about this project. I don't know what it holds, exactly what it goes on, or what exactly the engineer was thinking....All I do know if what they wanted and that I get paid for it....It is kinda funny how small the press in PEM's are and how big the rod is!As far as the chamfer goes I made sure not too deburr the holes too much but so far out of the 1000 I pressed in none have come out. I guess the next batch i'll make sure to keep note of that.Thanks for lookingMiller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
GMT+8, 2025-12-28 15:56 , Processed in 0.070066 second(s), 18 queries .
