For beginners- another light duty welding table with instructions
发表于 2021-8-31 23:01:36 | 显示全部楼层 |阅读模式
I know there are a million welding table posts, but many of them dont have simple instructions for the beginning welder.This table is only for light materials. I'm not strong enough to move a thick steel plate around, so the top is only 3/16. . It cannot accommodate a heavy vise but it is good enough to work on 20 ft lengths of metal tubing, angle iron, 1/2" rod, etc. It came with holes drilled into one side-very useful for bending metal rod. The dimensions are roughly 2 by 3' for the steel top, and 2 additional feet for the burning table.Here are some tips that I didnt know when I started making this:1) cut the top by scoring a straight line with an angle grinder and a cutoff wheel, and then go over the score several passes until the cut is completed. It will probably require 3-5 wheels. Alternatively, use a torch or plasma cutter (but if you have these items, you are not a beginner and dont need this post!). Dont forget to round the edges and corners for safety.2) Use 1.25" steel tubing (thick walled is better) for the legs and top frame. Thinner angle iron is fine for the lower support.Include at least 3--4 steel tubing braces under the top to prevent warpage from heat.I've used this table for oxyacetylene welding and have not had any problem with warpage.Make sure the steel top extends at least 1-2" past the top frame on all sides so there is enough material for clamps to attach.3) How to attach the wheels:For wheels which allow the table to be leveled, get the type of wheels which have an attached bolt and get hex nuts that fit this bolt. Weld the hex nut onto a drilled-out 2 by 2" metal square, and then weld this square, hex nut facing up into the leg,  onto the bottom of the table leg. Plan on ruining a few nuts due to welding slag getting into the threads. This is much easier to do with the table upside down. If you are sure your table is level, the wheels that have an attached plate can be used instead.I hope this helps fellow beginners. Attached Images
Reply:NICE. Simple. Useful.I am not a beginner but I never built a table. I kept using sawhorses and such. They tuck up out of the way. Due to the hassle, I usually ended up welding on the ground. Your table will get tons of use. I bet even if you built a killer dedicated welding table that this small one will still get used a bunch or handed down to someone who will use it a bunch. Thanks for the post!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I like that its a cutting table on one side and a welding table on the other. Only thing I would add is some expanded metal on the bottom for a shelf.
Reply:Nice table, simple yet very functional.
Reply:That will work. It looks tall. My kind of table. I hate those low bending over type tables and equipment.
GMT+8, 2025-12-28 16:02 , Processed in 0.075848 second(s), 18 queries .
