Another TIG Save
发表于 2021-8-31 23:01:35 | 显示全部楼层 |阅读模式
I had to replace this very expensive hand winch because some moron decided to run the cable under the idler shaft and destroy it.I figured I could use this somewhere and the fact that they are $450 new made me want to repair it.TIG welded with a 1/16" tungsten stuck out far to get in the groove, I used 309 filler because you never know what they make these things out ofAll done ready for something when I need a winchDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:well, at least the wear was even. Gotta look on the bright side some times.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Holy cow! Am I to understand that the cable wore away that whole groove?!
Reply:Originally Posted by joshuabardwellHoly cow! Am I to understand that the cable wore away that whole groove?!
Reply:Wow! Talk about abuse. Nice fix and save.
Reply:Let me see you do that with a stick welder....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterLet me see you do that with a stick welder....zap!
Reply:Originally Posted by millratAre you offering you're positioner to borrow on your dime?
Reply:Nice repair. I can't tell from the first picture but it appears to have cracked through. Did you re-assemble it for the photo or did someone catch it right before it really tore things up?
Reply:It cracked when I tried to drive the pin out of the gear to pull it apart, I finally said the hell with it and welded it where it sat. I did think long and hard about spinning down a new shaft, but the cost ouweighed the gain.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Nice save, and lucky you, getting to keep the repaired one."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:i guess the biggest challenge was not welding it to the bushing that carries it..
GMT+8, 2025-12-28 15:56 , Processed in 0.065478 second(s), 18 queries .
