Brass Draft tower
发表于 2021-8-31 23:01:32 | 显示全部楼层 |阅读模式
Thinking of buying this and trying to fix it I like old bar stuff and I can get this cheap. I have no experience with brass not even sure what grade it is. I do tig weld and am fairly decent at it and willing to try anything once. I have no oxy fuel experience at all but again willing to try. Opinions on this repair difficulty level, process, what type of brass is it, tig rod to use, silver solder, any ideas.  There is a tear on the third tap that extends to both sides of the faucet Attached ImagesDonnelly Small Engine & WeldingFoley AlabamaLincoln 225 TigLinoln 215 migHypertherm Powermax 65Ellis 1600 sawEllis 6000 belt grinderJD2 Model 4 tubing benderAtlas  12"X54" metal latheLots of large hammers
GMT+8, 2025-12-28 15:57 , Processed in 0.100043 second(s), 18 queries .
