Loving it more everyday
发表于 2021-8-31 23:01:31 | 显示全部楼层 |阅读模式
Trying every setting I can to see what it's all about.........  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:B_C, you made my day.  Good thing I had just swallowed that swig of beer.  What is that, "weld like an Egyptian" or Celtic runes or what?"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Great stuff.
Reply:LOL reminds me of when I got my own inverter Tig. Every piece of scrap 6061 disappeared from the lab and ended up as..err..well you could call it modern art I suppose Nice consistent beads and doing stuff like smilies/curves I think helps when you get stuck with a piece that has changing surface profile/weld angle. Also it's just fun :PFinding the pulser function almost made it feel a bit like cheating hehe.I need to go hit up local shops/scrap sellers to see what I can get by the pound. I've used up all the lose ends the lab had left overHTP Invertig 221-DV -- get's dragged everywhere.Syncro 200 -- "The Boat Anchor" at the lab.Lincoln 125 MIG
Reply:I do have a question though, on my quick set up sheet that came with the Dynasty it seems to be incorrect?   I set the EN with a higher number than the EP  like it says to save the tungsten and get more penetration and the arc is real bright and the tungsten starts to BALL.......If I use more EP  than EN   it welds great and the tungsten stays sharp?    I have used anywhere from Same to 1:8  ratio  is there a mistake on the Plastic set up sheet?  I used 170 weld amps 100 EN and 150 EP 71 Bal   120 Hrz.....3/32 Cereated tungsten  25/75 helium Argon gas and it welded great the more EP I run the better the tungsten holds its sharpness.....Weird?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Some people have way too much time on their hands....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Does it work ok on steel? What you are finding is very weird to me. None of mine work the way yours does.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Double post.....thought I could delete oneLast edited by vwguy3; 11-08-2012 at 09:35 AM.
Reply:I'll start the bidding on BCs art at 1.00Looks good BC.....wish I had a fraction of your skill.
Reply:I don't care what anyone else says, those pieces look like a great way to gain practice, practice, practice.Question:  Can TIG be used to add hardface?- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by zapsterSome people have way too much time on their hands....zap!
Reply:Originally Posted by B_CTrying every setting I can to see what it's all about.........
Reply:Originally Posted by B_CI do have a question though, on my quick set up sheet that came with the Dynasty it seems to be incorrect?   I set the EN with a higher number than the EP  like it says to save the tungsten and get more penetration and the arc is real bright and the tungsten starts to BALL.......If I use more EP  than EN   it welds great and the tungsten stays sharp?    I have used anywhere from Same to 1:8  ratio  is there a mistake on the Plastic set up sheet?  I used 170 weld amps 100 EN and 150 EP 71 Bal   120 Hrz.....3/32 Cereated tungsten  25/75 helium Argon gas and it welded great the more EP I run the better the tungsten holds its sharpness.....Weird?
Reply:Originally Posted by GambleI have a question. Maybe kind of noobish, but is it because of the helium? Are the settings they give you based on straight argon?
Reply:Originally Posted by MondoQuestion:  Can TIG be used to add hardface?- Mondo
Reply:Yeah I gave that a thought also but it doesn't effect  my Lincoln Sq. wave other than helping build heat in the part.......Im leaving the EP and EN  set in SAME  and just using the wave bal. to get penetration or cleaning  until I figure this thing out  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by vwguy3Yes,Crown HS-7-10 or Eureka 74
Reply:Hard Facing,  what does that have to do with my post?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CYeah I gave that a thought also but it doesn't effect  my Lincoln Sq. wave other than helping build heat in the part.......Im leaving the EP and EN  set in SAME  and just using the wave bal. to get penetration or cleaning  until I figure this thing out
Reply:Just got off the phone with Miller and those guys tell me to start off with a small ratio maybe 1.1  or 1.2  EN  EP    I pretty much decided that the BAL. still decides the PEN and CLEANING  effects and setting the EN and EP  won't be that necessary for my stuff I weld.....Clean 6061 Aluminum.....I tried SAME in the settings but  it likes a little more EP  to make nice welds?  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I learned something today, too much cleaning action will ball up the tungsten. Watch this[ame]http://www.youtube.com/watch?v=ubrnQT_XLK0&feature=g-all-u[/ame]Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:It cracks me up so much when me calls himself "Mr Tig".
Reply:Originally Posted by B_CHard Facing,  what does that have to do with my post?
Reply:Oh yeah that's right  unobtanium 33  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rockcheck that you have the leads on the right sides, I messed mine up on the first setup.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I have it set up right or it wouldn't weld as good As it does  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-28 16:02 , Processed in 0.099489 second(s), 18 queries .
