Im working on my
发表于 2021-8-31 23:01:26 | 显示全部楼层 |阅读模式
razor welding, and thought I could get some pointers.  Dagone bead looks awful.Aluminum cans are out of the question for me, I just blow holes even on the lowest of low settings (even on the bottom and the tabs).. Attached ImagesVarious GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:The only way I even got the aluminum can to stick was arc off on the table then move to the aluminum otherwise when I arced off I just blew a huge hole.  Then I'd look around to see if anyone was watching  I think our tig has issues anyway DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Do you have a remote amperage pedal or are you just setting your current and scratch starting ?
Reply:Ive got a pedal.  HF start.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:What's the lowest amperage your TIG can run?Use the smallest tungsten you can get 0.040" or 1/16" very sharp.Tightly clamp the butting edges, or zap a tiny tack at each end, any gap will kill you.Keep the arc gap as tight as possible, by machine welding I would set the gap at 0.030", by hand shoot for no more than 1/16".Were you trying to add filler?, you should be able to just fuse the edges without filler.Get a melt and move fast, looks like you dumped alot of extra heat into this weld, maybe moving too slow, too long an arc lenght, not a tight joint fitup?
Reply:5 amps is as low as she goes..  Tried it with 1/16 real sharp.You know, I didnt put the cans together, I was just seeing if I could lay a bead on the rim of the bottom.  Perhaps the extra thickness helps at the joint?  Yep, moved slow and was trying to get a little puddle going.  I ground down a er70-6 rod down.  It worked for a little bit.. heh.  Thanks for the tip.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-28 17:41 , Processed in 0.206904 second(s), 18 queries .
