Table with a fence for use with Plasma Cutter?
发表于 2021-8-31 23:01:23 | 显示全部楼层 |阅读模式
Hello all,Has anyone made or seen a table with a fence (similar to a bandsaw table & fence setup) that can be used with a plasma cutter?If so, what is your opinion of them?Thanks....MetalBob
Reply:I've made a stack of drawings this morning, trying to figure out something similar.  I am thinking of making something like a woodworking panel saw with a socket/camp to hold the plasma torch where the circular saw head would go -- as long as the sheet has one straight edge, the guide would cut perpendicular to that.  Should be pretty easy to rig up something like that.
GMT+8, 2025-12-28 15:56 , Processed in 0.086963 second(s), 18 queries .
