auto darkening lens screwed?
发表于 2021-8-31 23:01:19 | 显示全部楼层 |阅读模式
So we got monsooned at work yesterday. My hood got flooded just getting back to the truck. It started out where it would stay permanently dark. I put it in the sun to dry, and it when light again. Sweet, right? Nope. I hit the battery check button and it went dark once but kinda sputtered instead of going dark again like it should. Now it's stuck light.Any suggestions as to what may work to fix it? Other than a new lens? I think i may be screwed, but it's worth a shot.
Reply:Batteries out, soak immersed in a container of ethanol overnight, dry thoroughly with heat or in s vacuum chamber, then try it again.
Reply:could be just the batteries are fried?i.u.o.e. # 15queens, ny and sunny fla
Reply:I was hoping to hear that. Just didn't want to spring for them if it's not an option. I'm broke! Thanks!
GMT+8, 2025-12-28 15:56 , Processed in 0.101009 second(s), 18 queries .
