Did someone's crappy weld end up in my tire?
发表于 2021-8-31 23:01:16 | 显示全部楼层 |阅读模式
Found this in my tire today:I never thought about it, but crap welds can break off and go into your tires. Either that or it is some metallic ore someone had in the bed of their truck. Picked it up and the roofing supply house this morning. All I know is that it is magnetic and looks like it could be a weld. If it was a weld; it was most likely on someone's truck or trailer. What do you think?Millermatic250Miller Spoolmate 200Miller Spoolmatic 1Lincoln tombstone with century DC converter1945 K.O. Lee company stick welder (looks like R2D2)Miller 30E feederHobart AH27 FeederMiller Thunderbolt AC/DC
Reply:it's meteor $h*!TO INVENT  YOU NEED A GOOD IMAGINATION  AND A  PILE OF JUNK'' - THOMAS EDISONMost Of The Time People Don't see The Quality of a Good Job Unitl they see a Bad Job !! -Scott Esplin
Reply:Just doesn't look like a weld to me. Maybe some slag or over pour from a foundry? That sucks. Was the hole even fixable?200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:The left one does not look like a weld to me at all.The right one I can understand as it's stacked or layerd.  But I think it was just ripped off of something causing the layering or stacking, making it look like a weld.
Reply:I was teaching an employee to weld.  He did a perfect looking bead, but very cold on heavy plate.  The weld bead broke out in a perfect vee.  I showed him the problem but gave him the 3 inches of perfect looking "vee" weld bead.  I told him when he got home, lay on your stomach, place the weld bead in the crack of your butt, then tell your wife Bart was so mad he welded your butt closed. They never forgot that lesson.  Don't know what hit your tire, unless there was a naked guy on a motorcycle in front of you!
Reply:Originally Posted by bert the welderJust doesn't look like a weld to me. Maybe some slag or over pour from a foundry? That sucks. Was the hole even fixable?
Reply:Those are the 2 pieces of moon rock that someone stole from the government they have been looking for. Your a.ss is in trouble now as your the guy in possession of them now.
Reply:I thought I was clear, I welded the full moon shut. He tried to fart and burped instead.
Reply:Originally Posted by InkydoggyThose are the 2 pieces of moon rock that someone stole from the government they have been looking for. Your a.ss is in trouble now as your the guy in possession of them now.
Reply:Yeah, that looks like someones crappy old weld to me.
GMT+8, 2025-12-28 15:55 , Processed in 0.075262 second(s), 18 queries .
